MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Click for Johnson Evinrude Diagrams, Parts and Manuals!
Results 1 to 2 of 2
  1. #1
    Default Adjusting gear drive linkage on Johnson 2005 90 HP Engine
    How do you adjust the drive linkage on a Johnson 2005 90 HP engine? Shifting is very sloppy.
  2. #2
    Join Date
    Feb 2001
    Posts
    10,708
    Default Re: Adjusting gear drive linkage on Johnson 2005 90 HP Engine
    Uncertain as to what you need.... centering the shift cable is done as follows. Describe what you mean by sloppy shifting.
    (Centering Shift Cable)
    (J. Reeves)
    When all is as it should be, the proper method to adjust the shift cable is to disconnect the cable from the engine. Move the shift linkage on the engine to find the center of the play in neutral, and when found, leave it centered.
    Now, grab the end of the shift cable sleeve, push and pull it to find the center of the play there, and center that play.
    Adjust the trunion on the threaded portion of the shift cable so that the centered play of the cable lines up with the centered play of the engine's shift linkage. Install and lock the shift cable with the retaining clamp in that position. That's it.
    http://shop.ebay.com/Joe_OMC32/m.htm..._sop=12&_rdc=1
    Our questions require answers. If you refuse to answer our questions, how can we answer yours?
Similar Threads
  1. Forward gear removal, 2005 Johnson 50HP
    By blackrv7 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-14-2010, 08:29 PM
  2. KAD42 MARINE ENGINE DRIVE GEAR PROBLEMS
    By rainman77 in forum Volvo Penta Diesel
    Last Post: 06-22-2009, 05:20 PM
  3. Mercury 25 ML triggerthrottle linkage length adjusting
    By dk79 in forum Mercury Mariner Outboard Archive
    Last Post: 06-18-2009, 10:20 AM
  4. Help adjusting the control cables on 2005 Johnson 115 2 stroke
    By david_c in forum Johnson Evinrude Outboard Archive
    Last Post: 05-05-2008, 12:09 AM
  5. 2005 johnson outboard wont run when in gear
    By RL Hunter in forum Johnson Evinrude Outboard Archive
    Last Post: 03-12-2008, 08:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
