I rebuilt a 2802R (2 hp) Evinrude for a friend.
I know motors but not boat motors.
The water pump instructions say "run the motor and check the cooling system
operation by water spray from the idle relief hole"
Could someone please tell me where this hole is?
The driveshaft cover got pretty hot pretty quickly so I'm concerned something isn't right.
I didn't take the crank case apart so I don't know how the water circulates in the block.
Could the water system be blocked with crud?
Since I first wrote this I igured out that the exhaust exits through the down tube ....therefore creating the heat;but I've got no way of knowing that the pump is working.
Thanks.
Thanks.
