I am installing an AQ225D with 280 DP outdrive in my 1973 24' Searay. It came from the factory with either a Mercruiser or OMC not sure as they were both offerings for this boat. It was gutted when I purchased it. My question has to do with how to properly position the motor mounts. I have attached two pics showing stringers where the motor is to be mounted. As you can see I cut the caps off the stringers, as there was some water intrusion. Had to remove some foam and some rotted wood. Fortunately it was minimal with no damage to the stringers or transom. I am considering pouring some new foam about half full then bedding some aluminum backing plates in epoxy with Stainless lag bolts. My question is how to accurately position these. The centering is no issue my concern is the proper distance from the inside of the transom. I have considered two options.
1) Install the Transom Shield first then take measurements from there to position the bolts.
2) Cut slots in the aluminum backing plates so the bolts can be adjusted fore and aft. Then when the motor is in and bolted up I can poor in thickened epoxy.
Any thoughts on these or other methods.
