Results 1 to 3 of 3
  1. #1
    Default Compression check on a Johnson 50hp
    What is the correct procedure for taking a compression check on a Johnson 55hp and is the same for all outboards?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,492
    Default Re: Compression check on a Johnson 50hp
    Ground sparkplug leads. -----------Screw in a compression tester and crank it over. ---------------There is no need to " open the throttle " on a 2 stroke engine !!!!-------Read the highest pressure obtained.
  3. #3
    Thank you, I wanted to make sure we were going to do it correctly.......
Similar Threads
  1. Compression Check 1983 70hp Johnson
    By jnscherr in forum Johnson Evinrude Outboard Archive
    Last Post: 04-23-2009, 07:09 PM
  2. 1955 johnson 55 HP outbourd compression check
    By wheelersudds in forum Johnson Evinrude Outboard Archive
    Last Post: 04-08-2008, 09:53 AM
  3. Low compression check
    By jch324 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-06-2008, 01:41 PM
  4. How do i check if the Water pump is working properly Johnson 1975 50hp model 50ESL75 B
    By Katrina Turner in forum Johnson Evinrude Outboard Archive
    Last Post: 01-22-2008, 04:27 AM
  5. Compression check XP 150
    By rnd2g in forum Johnson Evinrude Outboard Archive
    Last Post: 04-19-2007, 05:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
