If you are going to do your own maintenance, then invest in a Helm shop manual - don't fool with the after market ones.
Checking/adjusting valves is pretty complicated on this engine. The following is abbreviated from the shop manual.
Remove silencer case
Remove throttle body and intake manifold
Disconnect two breather tubes and fuel tube
Disconnect wire and harness to the fuel cut off solenoid
Disconnect fuel lines from the fuel pump (low pressure side)
Disconnect tube from the fuel line cut out solenoid valve.
Disconnect 3P connector from each ignition coil and remove the main wire harness
Remove plugs & coils
Rremove the cylinder head covers
Remove timing belt covers
Manually turn crankshaft pulley clockwise to align No. 1 cylinder to TDC marks on both the sides of the timing belt driven pulleys with the marks on the timing belt back covers.
Intake vale - between 0.20 and 0.24
Exhaust valve - between 0.28 and 0.32 mm.
If adjustment is needed, it's the typical procedure - loosen the lock nut and adjust. Check & recheck each adjustment. Torque on the lock nut is 14 ft lbs.
Repeat with No 4, then 2, 5, 3, 6. Each cylinder TDC position is marked on the crank shaft pulley.
While you are in there, check the check the timing belt for wear and tension. Under 4.4 ft lbs of pressure, deflaction should be between 8.8 and 9.7 mm If off, adjust the tensioner pulley.
