redsnapper386
guy's, motor was running but idled rough.i installed new gauges,solinoids,battery,along with new motor,starter,alt,thunderbolt-4 dist,coil ,sensor,all wires checked,and clean.now motor turns over nice,but i noticed the volt meter was dropping down to zero. also noticed that when i operate the tilt motor up and down the volt meter dropped,and some gauge lights dimmed. i have run all tests that manual advises to no avail.most parts and componets are new or rebuilt.fuel delivery all good.have not replaced 50 amp breaker,turn key switch,battery switch,shift interrupt switch.the pin harness at motor is good,all plug ins good.any directions needed.thanks in advance.1987 sea ray,25 cc,350-300 hp. a-1 .
