I have an 05, 25hp 4 stroke that starts and idels perfectly. When I throttle up it will get on plane and then just cut out. It may or may not die and acts as if it has run out of gas. If it does die it will start right back up very quick and easy. I have replaced the fuel hose, cleaned the fuel joint/tank/fuel bowel and now do not know were to go other than clean/rebuild carb. The first time it did this I could not give it any gas at all or it would die.(I had to idle 5+miles back home). I gave it a good Seafoam treatment down the air intake and let set for 10 min. then ran it out. (did this several times) Motor ran real good for 1 day. Now it is doing the same thing only this time I can at least get it up on plane for a 100yrds. or so. I am thinking a possible obstruction in one of the jets, or maybe a stuck float.
Any suggestions on what else I should be checking out? Thanks for your help.
