Results 1 to 2 of 2
  1. #1
    Join Date
    Mar 2011
    Location
    St Pete Fla
    Posts
    16
    Default Synchronizing carbs and timing linkage.....? needed after cleaning carbs? 1977 55 hp
    The Service manual on my '77 55hp Seahorse (55EL77D) says i have to syn the timing and carbs after carb removal.....is that a should be done or must be done? What has changed just unbolting and rebolting the carbs?
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    15,776
    Default Re: Synchronizing carbs and timing linkage.....? needed after cleaning carbs?
    No, just make sure that the throttle butterflies open and close at the same time. The only thing you may have disturbed is the linkage between the carburetors.
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. Cleaning Looper Carbs
    By martino1 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-21-2009, 09:00 PM
  2. Cleaning carbs
    By bbhskynyrd in forum Mercury Mariner Outboard Archive
    Last Post: 02-18-2009, 01:09 AM
  3. Video on carbs cleaning
    By roscopico in forum Test posting of messages, photos and formatting
    Last Post: 02-13-2009, 03:05 AM
  4. Synchronizing carbs
    By funny_brew in forum Chrysler Force Outboard Archive
    Last Post: 10-31-2007, 01:51 AM
  5. Suzuki DT115 carbs needed
    By KenCo in forum Suzuki Outboard Archive
    Last Post: 08-13-2003, 12:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
