Results 1 to 5 of 5
  1. #1
    Join Date
    Dec 2010
    Location
    wisconsin
    Posts
    63
    Default I have a E-Z loader single axle trailer and a 19ft.Cobalt boat on it
    Hi All ! ok heres the story,I am moving from Wisconsin to Connecticut in May and am going to pull it with a 26 ft. U-haul Truck.I would rather have a Tandum trailer but this is all I can afford right now so it has to do.I have alot of concerns and a little nervous thinking about towing it 1,000 miles.I bought new tires C Rated trailer tires ,that are rated 1,850 pds a piece and yes I am going to get a set of fenders for it.I just want to know anyones opinion on anything else I can do for safety purposes and has anyone ever pulled a single axle trailer with a 2,900 pound boat before that far? Its going to be empty of fuel ect...My wife will be folling me in our Dodge Durango which is what I usually pull it around locally,but this is one hell of a trip.I have a spare tire ect.. and also what suggestions on tie down straps? Please ease my nervous mind LOL Thank you
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1923   Click image for larger version.
ID:	1924   Click image for larger version.
  2. #2
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    Default Re: I have a E-Z loader single axle trailer and a 19ft.Cobalt boat on it
    bring a grease gun and every third tank of gas or so hit the bearing with grease.
    Make sure the lights work and that you have the right kind og jack or bring some flat pieces of wood.
    I would also at home before leaving jack up the trailer so you know what you need remove ever nut so you know none are frozen and just drab of oil on the threads re-install them.
    Good luck ! It's a breeze.
  3. #3
    Join Date
    Dec 2010
    Location
    wisconsin
    Posts
    63
    Thank you so much Chief, I needed the encouragement! it does have buddy bearings and I got a grease gun full of grease! LOL I was just a lil nervous I have never ever pulled a boat that far and I"ll be damned if I leave my old dream boat behind......I was also concerned about the distance between the hitch and the vehicle it looked kinda close but never had a problem with my Durango pulling it as far as turning just opening the back hatch the the dodge was a lil close
  4. #4
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,662
    First and foremost, make sure the boat is properly set on the trailer. The tongue weight should be between 6% and 10% of the weight of the combined weight of the boat and the trailer. Also, make sure you have a safety chain hooked up between the winch holder and the boat bow - I didn't see one in the pictures. When I trailer my 6000 lb boat over distances, I also strap down the transom to the trailer to prevent any possible shifts. Follow Chief's advice on the bearing grease, but don't over do it, lest you blow out a seal.
    CHawk 25 DLX
  5. #5
    Nice conversation dude. This is the way to expose to your ideas. All the participants perform well according to their knowledge.
    Thanks man.
Similar Threads
  1. Trailer boat to Mexico Baja
    By gofast in forum Boat Towing Topics
    Last Post: 11-25-2010, 07:53 PM
  2. Boat Trailer
    By paul_rodgers in forum Mercruiser Sterndrive Archive
    Last Post: 09-02-2009, 01:42 PM
  3. Boat trailer question
    By bill_k in forum Volvo Penta Gas Archive
    Last Post: 06-14-2007, 05:03 PM
  4. How to get boat off trailer
    By david wesley in forum Mercruiser Sterndrive Archive
    Last Post: 02-15-2007, 07:38 AM
  5. What does my boat and trailer weigh
    By chris_rohde in forum Volvo Penta Gas Archive
    Last Post: 07-23-2006, 12:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
