Results 1 to 22 of 22
  1. #1
    Default oil leaking from water intake
    Hey guys, I'm new here, but from what I can tell you are a very helpful when people ask questions. I recently noticed oil leaking from my water intake grille area and don't know what I need to do to fix the problem. I recently purchased a water pump kit, because I know it is long overdue for replacing, and I also purchased a new lower unit gear seal kit. Did I buy the right parts? How difficult do you think it will be doing these replacements? I have a 97 Yamaha 30hp. Last year I redid my carbs, if that lets you know anything about my ability to turn a wrench. I just have not messed with this area of my motor before. Thanks, in advance, to those of you who provide valuable insight. Name:  th_IMAG0009.jpg
Size:  3.7 KBName:  th_IMAG0010.jpg
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    Default Re: oil leaking from water intake
    Yamaha oil seals are rubber inside and outside.--------------In cold weather they lose their grip on the housing!------------If water is in between seals in freezing weather the seals are displaced. ---------They start to leak !-------------Best to do an inspection.
  3. #3
    Thanks for the insight racerone. The seal displacement could be from the water freezing around the seals. I live in Charleston, Sc and we did not have that brutal of a winter this year, but we did have about two months of cold weather. Do you think I need to have the lower unit pressure tested, or just go ahead like I'm intending on doing, and replace all the seals myself. Have you worked on a Yamaha 30 hp before? Do I need any special tools?
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    In this case pressure testing before and after repairs will tell you if you did it " right "------------also let you know where the leak actually was.--------------No real special tools needed, a wrench to turn the big nut can be made up.--------I own a Yamaha 3 cylinder 30 amongst many other motors.
  5. #5
    Thanks racerone.
  6. #6
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    its your drive shaft seal
    replace that and the water pump since your in there already
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  7. #7
    Hey guys. I replaced the water pump and all the seals on the drive shaft, but I still have gear oil leaking. It is not leaking from the water intake grille anymore, but is now leaking from the small hole beside the water intake grille. You can see a pic of this hole on the right pic that I have above. It is directly to the right, or in front of the water intake grille, depending on how you look at it. I am really confused now, because I cannot imagine any seals being in this area and why this hole is leaking oil. Will replacing the seals on the prop shaft prevent leaking from this hole? It does not make sense to me that it would. Please help me figure this out.
  8. #8
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    If you are running on a hose in the driveway this is very normal. It is the unburnt oil from the exhaust.--------------The wee hole is a casting cavity drain.
  9. #9
    Racerone, I noticed when I was refilling the gear oil that gear oil was coming out of the wee hole, which is why I am concerned. It does not seem like gear oil should be coming out of the same hole as the water as fast as the gear oil was spewing out of the wee hole. I imagine this is where I am getting some of the water and gear oil mixing, making the gear oil milky white when I drain the oil. What are your thoughts? Do I need to be concerned? I really don't want to remove the lower unit again, as I have done about 5-6 times in the past week or so. Thanks.
  10. #10
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    Drain the oil for later filling and run / rush out to the boat shop to pressure test the lower unit !!!
  11. #11
    hi, I suggest to open the power unit from the foundation and check oil pump. Because you mentioned that you change the lower unit and the problem is still
    remain. i saw the picture of your lower unit. thank you.
  12. #12
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    its the shift shaft seal
  13. #13
    I don`t think so oil leaking from shift shaft seal, because there is no connection from shift shaft with oil. Is just a shaft which moves the gears
    forward and reverse inside the gear box.
  14. #14
    RS GoldRunescape GoldBuy Maplestory Mesos
  15. #15
    hi, my suggestion is inspect oil viscosity, because engine oil and gear oil has different viscosity, if the leaked oil less thicker then gear oil then it should be
    engine oil, if not then you must do pressure test and open gear box to inspect seals.
  16. #16
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    fine do not listen to me
    so when you get it pressure tested and they say its the shift shaft seal, then you can buy me lunch
    i work on motors daily for 3 yacht clubs, and you do not think i know what im taking about
    their is only 5 seals on lower units
    DRIVE
    PROP
    BEARING CARRIER
    DRAIN/VENT
    and a SHIFT SHAFT SEAL
  17. #17
    hey racerone, don`t be angry, many places has many name. you called it shift shaft seal but we called it gear selector. I really did not understand. sorry.
    my suggestion is remove the gear box from the unit and fill oil on the stand. at the same time check the leakage by pressure test. that would be helpful.
  18. #18
    I've been without the internet for a while, so I apologize for not getting back to you guys. I almost totally disassembled the entire lower unit and the problem was found in............ding ding ding. the shift seal. Thanks for all your help.
  19. #19
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    You can thank me later, lol
  20. #20
    Quote Originally Posted by justintime View Post
    do I need to remove the out drive to replace the seal?
  21. #21
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,726
    yes sir
  22. Default Re: oil leaking from water intake
    Quote Originally Posted by Leor View Post
    Hi Guy's👋 Im new to the site and sorry if I post things in the wrong place at times.I have a question for anyone that can really help me pls.I have a new out of the box lower unit for a 150 yahama.I filled it with oil and it's coming out of the water pick ups and a very small hole on one side of unit.Any help pls on this and what it can be or what to do.Thank You all and sorry for the long post as I'm new to this.Thanks Again
Similar Threads
  1. F150 4 stroke leaking oil from water intake
    By longboater in forum Yamaha Outboard Forum
    Last Post: 02-01-2011, 12:57 AM
  2. Wierd new gear oil leaking out of water intake??
    By [email protected] in forum OMC Sterndrive and Inboard Forum
    Last Post: 04-09-2010, 08:13 AM
  3. Gear oil leaking from water intake
    By seas_candy in forum Honda Outboard Archive
    Last Post: 09-09-2008, 06:27 PM
  4. Oil leaking from water intake on Mercury
    By agood1 in forum Mercury Mariner Outboard Archive
    Last Post: 05-17-2007, 10:30 AM
  5. 1976 omc sterndrive oil leaking from water intake
    By robw357 in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-12-2007, 11:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
