RicardoMarine
Gold Medal Contributor
I figured that you knew this stuff pretty well.Rick, I do have a good understanding on solenoids and what they do. What I was not aware of was they could be used like a relay.
Most of what I have used both in Marine and Machine Manufacturing, are the type that typically cycle on off wether with a mechanical link, open close a valve or to distribute power etc etc........Many years in industry. I just never had seen them used in this way. A relay yes..... a solenoid No.
I do understand all described above and also do not want to confuse anyone. The key here for me was the comparison to a relay. Even relays only like to be energized for so long........
As for a solenoid being a "relay"..... take the switches on a trim cylinder pump, for example. These are often refered to as "solenoids", but their function is that of a "relay". Yes/No?
There are also continuous duty "relays". Our late model cars/trucks likely have several under the hood. Fuel pump, for example.
Man............ am I high-jacking this thread, or what?
