Click for Bukh manuals!
Results 1 to 3 of 3
Thread: Bukh DV10 head
  1. #1
    Default Bukh DV10 head
    I have a bukh dv10 in my sailboat, and recently had water in the crankcase due to corroded water pump housing bearings. I also had a problem with the thermostat housing, and had to take off the head in order to get at it properly.
    On removing the head, I noticed that there are two holes in the head that match up with two holes on the top of the crankcase, leading to the water jacket. The head gasket also has holes in this spot.
    The issue is that the two holes in the top of the crankcase are blocked, with what appears to be metal, as picking at it does not loosen it. The opposing two holes were blocked, but easy to dig out.
    The question is, should I drill out the two blocked holes in the top of the crankcase?
    I have a manual, but the exploded view of the crankcase does not show these two holes.
    The water got in from the water pump, and I have ordered new bearings. The oil is now like mayonnaise, and I have managed to get most of it out from removing the head, the oil pan, and the front housing. I am also wondering if just replacing the oil and filter a few times will clean out the parts in the crankcase that I can't see.
    Any suggestions appreciated.
  2. #2
    Default Re: Bukh DV10 head
    Hi,
    I had a similar problem. Can't help you with the holes on top of the crankcase, but I do have a suggestion to get rid of the contaminated engine oil. I drained all of it in the normal manner and changed the filter. Then filled up to the noemal level with diesel oil and let the engine run at low revs for about 1 minute. After which I drained the diesel oil, changed the filter again and filled up with engine oil.
    Hope this might be helpful.
    Cheers,
    Swante.
  3. #3
    Thanks!
    I was looking for reassurance that I don't need to haul the crankcase apart.
    I'll try it your way.
Similar Threads
  1. BUKH DV20 Head Gasket
    By butterfish in forum Bukh
    Last Post: 01-16-2011, 07:35 PM
  2. m# dv10/20 rebuilt injector pump engine is racing
    By sailboat terry in forum Bukh
    Last Post: 01-15-2011, 06:14 AM
  3. Dv10 transmission
    By tabon in forum Bukh
    Last Post: 06-28-2009, 07:24 PM
  4. Bukh DV 24 ME
    By gwb in forum Bukh
    Last Post: 01-02-2008, 12:17 PM
  5. BUKH DV10 ME
    By MIKIE in forum Bukh
    Last Post: 05-16-2007, 02:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
