John Smith
i bought a 1980 johnson 70hp i believe
he threw in a set off controls that he had i was label for a 70 hp johnson
the problem is that i changed the water pump and thermostat on it before i even flashed it up
when i got it all back together and everything hooke up i put it in forward gear and it spins in reverse (counterclockwise)
when shifted into reverse it spin clockwise (forward)
was the shift linkage rod hooke up wrong or the wrong control box
the bell crank i have is the boomerang one that has a rod to the shifter up high down on a angle
where most are connected down below with the shift cables
not sure if i explained this right but i need help
