Matt, both helms are in parallel with one another. This changes the resistance that the sender must be capable of...... I still dont under stand the difference between the singe and dual staion sensors but Faria says I need them.
Matt
Define "Fresh Water Cooled". Some refer to a "Closed Cooling" system as FWC. If Closed System cooled, your operating temperature should be close to 160*/180*....... I also need temp and oil pressure swithches for the alarms. Can anyone suggest what temp the switch needs to close at? And what psi the the oil pressure switch should activate? Fresh water cooled 318's. Matt
Matt, that answer that question. Your best engine temp, IMO, will be 160*/180* since you have the closed cooling systems.Ricardo to answer your question the engines have a closed cooling system.
Matt
