polefroggy
Ok, I now have good coils, I have good spark from both plugs...Pulled that starter rope and ton of times, nuttin'.... no sputtering, no spitting, no popping, no nothin'. Pulled fuel hose from carb and checked flow from pump... excellent flow...the fuel gets to the carb but won't go further..... pulled the carb apart and verified.... found no fuel in the carb, no fuel smell...float bowl bone dry.
Based on posts yesterday, check my float needle once again, it does have a rubber tip... I have no clip/spring for it...is this the reason the carb is not taking in fuel? And if so, guess that means I need to get another rebuild kit.....
thanks to all for your help
