I use a friend's boat on the Santee Cooper system, last time down the 1990 force 125hp motor started acting up. While fishing we were leaving and I put the boat in forward and it started going backwards, after a little bit of pulling on the cables, the boat started going forwards in forwards and reverse in reverse. I think he has messed with the cables because to crank the boat in neutral the handle is not quite in the neutral setting. Anyway, the next morning when we tried to go out, I put the boat in reverse and it would pull straight forwards up on the bank. Ended up not going out, becasue that is the wrong lake for something bad to happen to your motor. I live 4 hours away, so I am trying to trouble shoot what to repair before I go back. Any suggestions? thanks for any help you can give. bk
