225 four stroke YAMA
I am having an electrical issue with my vessel. When the ignition switch is turned, the engine has no power. When it does turn on and the tilt button is pushed on the throttle, the engine turns off. My vessel is equipped with two new large battries with good readings. I am not sure if the electrical issue is in the throttle or igintion switch. BTW, the power switches are properly wired... Also, the engine turns on at times, this is when the tilt kills the power... Thanks....
