Not to sound cheap....but here are a few thoughts in a different direction. We had an ONAN MCCK 6.5 onboard when we bought the old Silverton 34C. We bought a 7Kw Westerbeke used with 320 hours on eBay for $700.00..clearly a good deal from what I am reading. It installed with less space and 100 lbs lighter between the port engine and the transom on a set of rails on top of the stringers. Having re-wired the AC and DC systems on board, our new AC electrical panel has a simple interlock for shore power or generator. It is a 2" slide bar that prevents the breakers from engaging simultaneously. According the the engineer who drew up the plans, our electrical load is easily handled with this system... a 16k air conditioner, microwave, dual voltage refrigerator, and TV entertainment system.We did re-install the intake water and exhaust pathways to increase the flow thru but the entire outlay, thousands of fe et of wire in sizes I never knew existed, 2 separate electrical panels 1 ac and 1 dc, remote start generator panels a new custom made cabinet for the entire starboard side will with acccess doors cost us about $4000. YES, we did all of the work ourselves. This is not our area of expertise but with a lot of research and the help of a dozen guys on this board ( and a S#!tload of work) it all worked perfectly from day one.
Our noise level is low, no detectable vibration, no extra insulation and with this vessel worth MAYBE $45k, no way were we going to drop another 12K into it. The boat does notice the 100 lb weight difference, she leans more to the right at the dock. The rest of it is no different... ONE MAJOR thing I learned that I would have never thought of: you cannot use a scoop on the water intake like we do on our air conditioning pump.... That is the story of how it worked for us. If you need any more details, I would be glad to share my experiences via email...
