NYC to VT by Hudson
anyone do this trip? wondering about what the top half of the trip is like. also wondering how i must modify the boat to disable the Y value on the holding tank. Also how do I disable the macerater?
thx scott
Re: NYC to VT by Hudson
Thinking of making pretty much the same trip, myself, as I am close to the Hudson, just a little further up stream, but not planning to all the way to Vermont. Have freinds North of Albany to boat with.
Just a thought, I believe removing the valve handle / locking handle is OK, legally. Disable the pump by pulling the fuse or disconnecting the wiring harness to it. Just check for yourself, as I am no legal expert, but I am pretty sure that is what is suggested on vessels used in various bodies of water. I believe the purpose is so it can't be "accidently" changed without use of tools / keys. Any wronful discharge would be the result of intentionally and/or manually changing lineup, hence allowing it to happen, making you liable, if caught.
If you do make this trip. Please re post to tell me how long it took you take make this trip. Thanks
bigwiggle
no but sounds interesting can you give me more info about it like distance weather?
Sound interesting trip and great sails.
www.brittanysail.co.uk
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
