I have a 1970 85HP electric shift engine that I had to replace the lower unit. the used
lower unit I purchased looks identical to my old one and even lines up perfectly, However the prop shaft is different from my original lower unit. The original lower unit had a straight shaft, while the new lower unit has a tapered shaft. About half way from the threads it
tapers larger and then one more time at the housing. I need a Thrust Washer and a Thrust
Bushing to make the prop clear the housing. I researched and found two part #s but not specification on if these are the correct size. The Thrust Washer part # 0313925 and Thrust Bearing # 0386072. If anyone has information regarding if these are the correct parts or if there is information I did not provide please let me know, trying to get boat ready for spring fishing.
Thanks David
Thanks David
