Results 1 to 6 of 6
  1. #1
    Default johnson 1979 25 hp model 25R79R
    i am having problems with this motor having no spark it ran fine when i took it off my jon boat now i put it on my pontoon and i cant get spark. i have checked the statorand everything else with a ohms meter and everything seems to be fine. I am confused can someone pls help me out.
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,308
    Default Re: johnson 1979 25 hp model 25R79R
    Does this engine have a wiring harness leading to an ignition switch, or simply to a push button to stop the engine from running? If a wiring harness, does it also have a kill switch & lanyard?
    Remove spark plugs. disconnect the black/yellow wire from the powerpack. Do you now have spark?
  3. #3
    yes it does
  4. #4
    Join Date
    Feb 2001
    Location
    Posts
    14,308
    I assume that you're saying that it has spark with the black/yellow wire disconnected?
    If so, how about this question that I asked (below).
    "Does this engine have a wiring harness leading to an ignition switch, or simply to a push button to stop the engine from running? If a wiring harness, does it also have a kill switch & lanyard?"
    You need to spell it out for me to eliminate a lack of communication.
  5. #5
    yes it has a wiring harness leading to the ignition and i have no spark with or without the black and yellow hooked up
  6. #6
    Join Date
    Feb 2001
    Location
    Posts
    14,308
    That problem is usually due to a failed powerpack.
Similar Threads
  1. 1979 25hp Johnson, 25R79R, won't run right!
    By skiffscott in forum Johnson Evinrude Outboard Forum
    Last Post: 02-21-2011, 03:12 PM
  2. johnson 25 hp 25R79R outboard motor with no spark
    By jimmymac13 in forum Boat Electrical Systems
    Last Post: 02-02-2011, 11:02 AM
  3. Johnson 85 HP 1979 Model 85TL79R
    By ko4nrbs in forum Johnson Evinrude Outboard Archive
    Last Post: 05-01-2008, 10:38 AM
  4. Johnson 85HP 1979 Model
    Last Post: 04-24-2008, 09:23 AM
  5. 1979 Johnson 55 hp model 55E compression spec
    By pandrew6l in forum Johnson Evinrude Outboard Archive
    Last Post: 07-21-2006, 11:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
