Results 1 to 18 of 18
  1. #1
    Default OMC Timing fixtures
    Hey everybody, I am new here and would like to say first off this looks like a great forum with a lot of knowledgeable techs on here and I hope I can offer my experiences and knowledge at some point also. The main reason I am posting today though is because I am looking for a set of Timing fixtures for setting OMC's Breaker points. I believe the part numbers on them are
    383601
    383602
    383603
    378966
    386635
    386636
    I believe there were only six in total, but there may be one more. If anybody has these and is interested in selling them please let me know, or if you know where a guy could get them I would also appreciate it.
    Thanks and I cannot wait to learn from you all and also hope you can learn some from me.
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,677
    Default Re: OMC Timing fixtures
    These are nothing but ---" dummy flywheels "-------------u can use the flywheel marks and the marks on the magplate !!--------------Visit the------------- AOMCI -----website I bellieve one contributor makes new ones.
  3. #3
    Join Date
    Apr 2009
    Location
    Perth, W.A., Australia. Residence 35 Lower Donnelly River
    Posts
    231
    Yeh, and if you have a dial gauge with adapter for spark plug offset (Or take the head off) , a felt tip marking pen, a degree wheel and a battery powered inductive timing light, multimeter and some thought with all that.......... you can actually get things as you want. Running on the fuel available to you as well.
    Just a note, always best to mark up and deal with your own flywheel as above.
    Under Our Sun?
    Nothing New
    Regards
    B
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,677
    NO NEED TO DO ALL THAT MARKING-------------timing marks are on all of the early OMC flywheels !!
  5. #5
    Join Date
    Apr 2009
    Location
    Posts
    231
    Really?
    Busted Mate. They are, as you stated, "Casting Marks"
    Core Shift?
    B
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,677
    Next time you run an older OMC , aim a timing light at the two vertical marks on the magplate.-----------You will then see the timing marks on the flywheel as well.----------These can also be used for setting the points correctly------------------------And I have been doing this since 1968-----You are busted !!!
  7. #7
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,309
    Jogin.... Sent a private message.
  8. #8
    I never really thought of using the timing marks on the flywheel and corresponding them with the timing marks on the mag plate. I guess the only issue I have with that is having to remove the flywheel each time to adjust the point set screw. This bothers me since Removing the flywheel I am sure it will turn the crank a bit. Thanks for the input and help, and I will check out AOMCI to see if they have them for a reasonable price.
  9. #9
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,677
    If you lock the magplate some how and carefully remove the " loose " flywheel , then nothing goes out of position.------------I have the fixtures , have used them many times.--------Sometimes when I can't find them in a hurry I set the points the other way.--------------I never use feelers to set points !
  10. #10
    Join Date
    Feb 2001
    Location
    Posts
    14,309
    (Point Setting Of Magneto Models)
    (J. Reeves)
    Set the points as follows. Have the flywheel key aligned with the fiber rubbing portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
    NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
  11. #11
    Red face Re: OMC Timing fixtures
    Quote Originally Posted by joereeves View Post
    (J. Reeves)
    Thanks for this post. I purchased an OMC manual and the procedure shown in it required special tools and using marks and such. So I tried your procedure. It was easy and it seemed to fix the last of my problems (which was poor performance when accelerating from slow). The points were only off by a few thousandths but it made a difference.
  12. #12
    Fixture and feeler Guage I think would be way more accurate than light and eye balling lobe on drive shaft
  13. #13
    I would think that using a timing fixture set part set to the midway point between the two timing marks on the armature plate then adjusting the points with a 20 thousands feeler gauge would be way more accurate than any light or eyeballing the lobe or the flywheel key on the drive shaft, then you are ensuring that the points open at exactly the right spacing perfectly opposite from each other.
  14. #14
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,677
    ?????--------------No , using those fixtures or the actual flywheel and a light or buzzer is more accurate than using feeler gauges !!!!
  15. #15
    Quote Originally Posted by racerone View Post
    I understand the fixtures and timing marks on the armature or flywheel, not getting how a light or buzzer can be more accurate than the feeler Guage at measuring 20 thousands gap between point contacts.
  16. #16
    Join Date
    Feb 2001
    Location
    Posts
    14,309
    NOTE: This post is over four (4) years old..... Start a new post.
    However,,, ignore the light and buzzer thing. The gauge at .020/.022 setup gets you within factory specifications.
    We occasionally have questions. If you fail to answer, it may affect ours.
  17. #17
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,677
    The light or buzzer detects where the points open and that is the critical thing on a magneto.-------The actual gap is of no consequence.
  18. #18
    Join Date
    Feb 2001
    Location
    Posts
    14,309
    Whatever... BUT... I tried a flashlight and a overheat warning buzzer and it didn't work worth a damn!
Similar Threads
  1. Timing Cover Missing Timing Marks
    By troym in forum Mercruiser Sterndrive Forum
    Last Post: 10-21-2010, 12:59 PM
  2. Eratic timing marks at idle with timing light. 1989 2.3 L
    By NewBoatGuyGeorge in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-23-2010, 11:39 AM
  3. Timing Fixtures
    By oldtrafficcop in forum Johnson Evinrude Outboard Archive
    Last Post: 03-22-2009, 09:15 AM
  4. 283 Chris Craft Timing How do I set timing
    By Jim Hawver in forum Chris Craft Engine Forum
    Last Post: 03-20-2008, 07:17 AM
  5. Proper timing for 454 Different timing marks
    By rmm in forum Crusader Marine Archive
    Last Post: 08-01-2007, 07:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
