Results 1 to 7 of 7
  1. #1
    Join Date
    Jan 2011
    Location
    London and France
    Posts
    2
    Default 1960 Evinrude Lightwin 3hp, type 3034, fuel/oil mix???
    Hi,
    New to this forum and to the Evinrude Lightwin. Mine is a 1960 model, it seems in good condition and in terms of design is light-years in advance of the Seagull I have, and I want to keep it that way! I am confused as to the correct fuel/oil mix. I contacted Evinrude and was told 50:1 was correct, but the engine was made at a time when 25:1 was current lubrication technology, and others have suggested 16:1 might be appropriate. Is there any definitive advice out there?
    By the way, is there any salt neutraliser I might use for flushing? I will be using the engine in the sea.
    Peter
  2. #2
    Join Date
    Jun 2008
    Location
    springfield , ohio, usa
    Posts
    31
    Default Re: 1960 Evinrude Lightwin 3hp, type 3034, fuel/oil mix???
    Hi, I'm a Pete also. . .and have a 1960 3034 as well. I just got mine running after rebuilding the carb, and I used a 24:1 which smoked a lot. I've read previous threads that say 50:1 will work, as long as it's TC-W3 or better. Then again, I've seen some that say it won't, because the older motors used bronze crank bushings instead of roller bearings. So, I guess I don 't have a definitive answer. Likewise, I'm not much help w/ saltwater...I'm strictly freshwater. But having seen one long ago, I agree it's a step up from a Seagull.
  3. #3
    Join Date
    Jan 2011
    Location
    London and France
    Posts
    2
    Many thanks for the reply. I used the engine for the first time yesterday, and it worked fine. I used a 25:1 ratio, with a biodegradeable oil, having taken the advice from someone on another forum suggesting that in the absence of any definitive advice, 25:1 is the best compromise for all two-strokes. He seems to be correct - no problems at all and the engine runs like a sewing machine. As for the Seagull, whilst a little agricultural, they seem to be the most reliable engines on the planet. But a little rough, compared with the sweet Lightwin. I now have a 6hp Evinrude and hope for similar performance, although with a 50:1 fuel mix - and a bigger boat!
    Kind regards, and the photo shows my little Northumbrian Coble on the etang in southern France yesterday, with the Lightwin on the transom,
    PeterClick image for larger version.
Name:	Coble Evinrude email.jpg
  4. #4
    Since I'm in salt water more than fresh, I'll chime in here. All you need is a little tool we call the ears. They fit on the lower end and you hook up the garden hose. Turn it on. You can run the motor if you like, but it's not essential. You need no chemicals.
    As for Sigean's comment concerning the British Seagull, I enjoyed your humorous assessment of that boat anchor. I don't think there was ever a more poorly built and designed motor on the planet. And 10-1 oil ratio? I should have been a diesel. I'd rather row, I'd get there faster.
  5. #5
    Just acquired a 1960 JW 16 Johnson 3 hp Lightwin.. coils were a mess as was the carb.. new coils,points , condensors, rebuilt carb... the old girl is running
    like new... at 25:1 TC-W3 Amsoil
  6. #6
    Quote Originally Posted by kimcrwbr1 View Post
    Back then they just used 30w motor oil with leaded fuel. Now a days with unleaded the TWC-3 oil is a blend to protect the internal parts. TWC-3 atands for two stroke water cooled -3 is the lead equilavent.
    Uh, actually it's TC-W3. The TC indicates 2 cycle oil, W indicates the oil is suitable for water cooled engines, and the 3 on the label means that it is a third-generation oil. The TC-W3 certification replaced the earlier designations TC-W and TC-WII, and indicates that the oil has passed additional testing procedures designed to exclude inferior oils.
  7. #7
    I recently got a "59 evinrude and all my research says 24:1 with ethanol free gas and a marine grade 2 cycle oil.
Similar Threads
  1. Carb Synchronising Evinrude 3034 3Hp
    By collector_inspector in forum Johnson Evinrude Outboard Forum
    Last Post: 09-03-2010, 01:32 PM
  2. Looking for a lightwin fuel system solution
    By cbreaux in forum Johnson Evinrude Outboard Forum
    Last Post: 02-07-2010, 09:23 AM
  3. 1952 lightwin fuel
    By neil cross in forum Johnson Evinrude Outboard Archive
    Last Post: 07-01-2007, 10:07 PM
  4. Evinrude 3HP Model 3034 Serial number 10387
    By ko4nrbs in forum Johnson Evinrude Outboard Archive
    Last Post: 07-01-2007, 12:28 AM
  5. 1960 model Evinrude 3034 outboard parts
    By Mark Carpenter in forum Johnson Evinrude Outboard Archive
    Last Post: 08-08-2003, 07:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
