Results 1 to 4 of 4
  1. #1
    Default 1999 yamaha 9.9hp 4 stroke choke
    Will an Evinrude choke cure choke problems on a 1999 Yamaha 9.9hp 4 stroke outboard? I was told that it can be done on a 150hp successfully, just wondering if that is even true? I have a 1999 9.9hp 4 stroke Yamaha that has perpetual cold starting problems. Unless I remove the cowling and cover the choke screen with my palm it won't start. That gets a little tiresome having to do that every time I want to start the engine, especially if I have to do it on the water. If an evinrude choke in fact will fit and will work better what are the parts I need to order and does anyone have any experience with doing this and how? lot of questions but I really need help with this motor?? Bob W
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,716
    Default Re: 1999 yamaha 9.9hp 4 stroke choke
    You can install a manual primer from an OMC ----found on the later motors , say around the late 80's early 90's---------- 20 / 25 /30 HP--------------just the primer / nipple and some hoses/ and some research.
  3. #3
    i am new here but have a 2000 9.9 4stroke. it has been trouble from day 1. its a long story but i bought it new the dealer went out of biz and all the work i had done i paid for. does yours have a choke? mine does not it has a fuel enrichment system. i finally found a mechanic that called yamaha techs and changed the linkage adjustment under the carb. also the only way to start mine is to put it in gear rev the throttle 3x go back to neutral and pull. this fixed starting problem i posted a different problem im having now.
  4. #4
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    alexava
    start a new thread please
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. 1999 yamaha 60 hp 2 stroke,starting problems
    By catfishsnook in forum Yamaha Outboard Forum
    Last Post: 07-23-2010, 10:40 AM
  2. Historyexperience w 1999 Yamaha 100 4 stroke
    By dlippert in forum Yamaha Outboard Forum
    Last Post: 12-28-2009, 12:13 PM
  3. 1999 Yamaha 50 four stroke
    By coolcool in forum Yamaha Outboard Archive
    Last Post: 10-01-2008, 01:09 PM
  4. YAMAHA 6J8 1989 30 2 STROKE CHOKE PROBLEM
    By dimitris_kalaitzidis in forum Yamaha Outboard Archive
    Last Post: 07-28-2008, 03:55 PM
  5. Yamaha 6hp 2 stroke starts but stalls when choke is disengaged
    By bruce_g in forum Yamaha Outboard Archive
    Last Post: 05-31-2007, 11:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
