Reservoir Dog
I've been undergoing break-in of my new 8hp Nissan tiller S# 038884AX. First two outings went completely normal, kept the throttle low except for a few minutes here and there. No problems first two outings equaling 3 hours on the motor.
Third outing this weekend was not so good so I'm trying to figure out what might be the problem.
This outing my motor started up just great in choke but no matter how long I let it run in choke, when I released the choke the motor would not idle with the tiller in less than halfway past "restart" section and I would almost have to give it a little throttle boost to keep it running. It was hard to restart without just using the choke to get it going. Seemed to choke great, starting quickly. I ran the boat briefly (bout 400lbs. Worth of Jon boat) and it was hard to keep the rpm's low to shift into gear. As the boat moved in gear it seemed to fluctuate power or rpm's slightly in a pattern up and down slightly in whatever throttle range I tried the boat.
I adjusted the brass screw on the throttle arm to give it a slight amount of gas right at the restart section of the throttle (I did not touch the idle screw) and it seemed to work but rpm's seemed high and idling in gear seemed to fast. Plus power still was a little fluctuating. I think I made a mistake messing with that screw now, I realize that was probably not the way to fix it.
On a side note, I have not been running the gas out and it has been exactly 4 weeks. I did add gas and I only use 93 grade.
After I added oil for the first time, it measured almost barely under full, now it almost seems like there is more oil in there and maybe over full.
Another thing I notice is that from 3/4 throttle to full throttle there is no difference and actually seems to get more power back at 3/4. This has been briefly done while I'm still in break-in hours.
I never cleaned the gas tank before using it and disconnect the line from the motor between uses.
Any suggestions on what might have happened would be greatly appreciated. I bought this motor online and would like to learn to fix it myself if possible.
