There is no 23 T listed , GEN II lists as 1.62 so it could be a 23T gear.
Either one will work ok with a 6 cylinder motor.The following is from SEI.com
1995 and older (22/20 tooth upper, 17/28 tooth lower) 1.5 ratio
1996 and newer (22/20 tooth upper, 13/21 tooth lower) 1.47 ratio
1995 and older (24/24 tooth upper, 17/28 tooth lower) 1.65 ratio
1996 and newer (24/24 tooth upper, 13/21 tooth lower) 1.62 ratio
1995 and older (17/19 tooth upper, 17/28 tooth lower) 1.84 ratio
1996 and newer (17/19 tooth upper, 13/21 tooth lower) 1.81 ratio
1995 and older (20/24 tooth upper, 17/28 tooth lower) 1.98 ratio
1996 and newer (20/24 tooth upper, 13/21 tooth lower) 1.94 ratio
__________________
