The rpm at WOT is 3900-4000 and I would like to be able to get a little more rpm and speed out of it. The carb is the same as the 120 and 140 hp, so I'm thinking that may be the limiting factor. From what I'm hearing here, it doesn't sound promising as I don't want to divorce the intake and exhaust manifolds.
maybe the op is looking in the wrong place for the cause of low wot rpm.
I " believe " recommended wot is 42-4600 rpm.
So your only 200-600 rpm off the mark.
IF The tach is correct. Is it ? You checked it against a know shop tach that is correct ?
So say the tach is correct !Compression is what ?
Fuel pump is giving what psi ?
Water in the hull wet stringers ?
I'm just looking for a relatively easy way to get another 300-400 rpm out of it with the 21" prop.
Ayuh,... It Ain't gonna happen...
Drop to the 19" prop to get the rpms up... You're lugging it at 3800rpms at Wot...
That motor won't mind a 4400/ 4600rpm Wot, so long as you don't run it at Wot for extended periods...
the 200hp 292 Mercruiser in 1969 used a Quadrajet carb...
I thought all the 165's had a manifold that could accept a 4 BBL by removing the adapter plate
