The manual will help....so would a scan tool......
A clear statement of your problem would be good too.....you inferred an issue with the starboard(?) engine's fuel delivery....won't idle, won't start, dies under load, etc?
Certainly. And your help/interest is greatly appreciated.
SB engine stopped running when leaving marina. Restarted SB engine, turned around and docked. On another attempt days later, same scenario. On yet another (final) attempt days later, I let SB engine run/idle for several minutes while at dock and the engine stopped running. It restarted and ran for only 10-15 seconds and stopped. I have not been able to restart SB engine since then.
I have been following the electronic fuel pump diagnostics flow:
- Transmission lever in FWD, ignition held in START, does pump run? NO
- Check/reset (I replaced, just to be sure) 10-amp breaker, Transmission lever in FWD, ignition held in START, does pump run? NO
- Remove power from fuel pump, check for power with test light, Transmission lever in FWD, ignition held in START, is there power? NO
- Transmission lever in FWD, ignition held in START, check for power at 10-amp breaker on purple/red wire, is there power? NO
- Transmission lever in FWD, ignition held in START, check for power at 10-amp breaker on purple/yellow wire, is there power? NO
- Transmission lever in FWD, ignition held in START, disconnect 3-wire connector at oil-pressure switch… this is where I am and cannot find the switch in order to test/replace
Also, I have connected 12 volt power directly to the fuel pump and it ran fine. I am trying to be systematic about this. Any other routes or suggestions are appreciated.
