Well, it's been a while so first I'll say hi everyone. My problem, The last couple trips out with the boat I have experienced the lack of power or acceleration after trolling all day, would not climb above 1000 rpm under load. Trolling for me is performed at low rpm around 700 for 7- 8 hours. The first time this happened I figured I had just loaded up the plugs, stopped changed them even though they didn't look bad and no difference still 1000 rpm under load. I was then advised it was a electrical problem likely caused by the condensor, so I changed the coil, cap, rotor, points and condensor. Also this motor has brand new plug and coil wires. The next time out without doing any trolling I again was restricted to no acceleration after all the changes I could only muster 2500 rpm with everything being brand new. I am now thinking it's a fuel restriction problem maybe the fuel pump is gone, I have changed out all 3 fuel filters every time I have serviced the engine. When the engine is hooked up to the ear muffs and run it seems to perform perfect, but when in the water it's a whole different story. All advice and options are greatly appreciated. Could it be a outdrive problem? Never had any problem with it, no noise etc, etc.
By the way Hystat this motor does run absolutely perfect!!!!!! Thanks
