I have a 2001 BF50 and it starts and idles great. If I throttle up the engine out of gear the RPM's climb up smooth. The problem I have is when I throttle up the engine in gear it dies. If I pull back the throttle and feather it up it will sometimes rev up, but most of the time it dies.
To correct the problem I replaced the gasoline (Used an external tank with fresh gas) and fuel filter. Same problem.
I changed the plugs and checked and have spark on each of them.
I then replaced the fuel pump. Same problem
I had the carbs removed and cleaned and new gaskets and I still have the same problem.
I am not sure what to do next. Has anyone else had this type of problem and if so what would you try next?
Thanks,
Ron
Thanks,
Ron
