Click for Volvo Penta parts and manuals!
Results 1 to 6 of 6
Thread: Volvo duo props
  1. #1
    Default Volvo duo props
    I have a VOLVO 280 duo prop out drive with the AQ 260 engime, I'm currently running B5 props and it is slightly over propped. Is it possible to use type D4 props to achieve propper WOT
    will these props fit?
    THANKS in ADVANCE
    Cheers
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,417
    Default Re: Volvo duo props
    You do not mention the size of the hull, nor the final drive ratio.
    People get this wrong all of the time.
    The fact that you can run 5's, may indicate several things:
    • Re-pitched props that were not re-marked
    • Smaller, light weight boat
    • Incorrect over-all ratio
    None-the-less, your WOT RPM is of most importance (just as you would with a single prop drive). To over-burden your engine is asking for pre-mature failure, IMO.
    If the ratio is correct, I'd drop down to a set of B-4's, and give them a try.
    Again......., OEM spec'd WOT RPM being your primary goal.
    The "D" series is a Diesel application.
    Volvo recommends the B (aluminum) or C (SS) for this drive and gasoline engine.
    Hope that helps you!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  3. #3
    I have a 26 FT Hourston with a final ratio of 1.95, boat weighs approx.6800 LBS.
    I am getting 4000 RPM @ WOT I do realize that the "D" series props are for diesel
    application But could I use them or do I need to stick with the type B series
    Thanks Again for your input
    Cheers
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,417
    OK..... for this hull, the 1.95:1 sounds correct!
    However, your WOT RPM of 4k is too low. You'd best bring this up, by down sizing the prop set, IMO.
    Make sure that your tachometer is accurate!
    The answer to the question of "will they fit?", is yes..... they will mount up!
    However, as suggested earlier:
    Volvo Penta knows much more about this than I do.
    My knoweldge is limited to this:
    First off, the diesel final drive ratio may be taller (numerically lower).... 1.78:1, for example (depends on which diesel engine).
    Secondly, the diesel engine WOT RPM will be much lower.
    Therefore I cannot, and will not, recommend the "D" series for your application.
    Sorry!
    Portland, Oregon
  5. #5
    That's all I needed to here thanks for all your help
    You seem to have a plethera of knowledge and I Thank You
    Cheers.
  6. #6
    Quote Originally Posted by zapper1 View Post
    THANKS in ADVANCE
    Cheers
    Do you still have the B5's and do you want to sell them?
Similar Threads
  1. 1989 285 volvo outdrive what props are avalible
    By invader186 in forum Volvo Penta Gas Engine Forum
    Last Post: 02-16-2010, 01:23 AM
  2. Older Volvo props
    By rossbrown in forum Volvo Penta Gas Engine Forum
    Last Post: 10-29-2009, 11:32 PM
  3. Can 200 props be made to fit Volvo 100
    By vovo222 in forum Volvo Penta Gas Archive
    Last Post: 04-20-2009, 12:29 AM
  4. Volvo Penta XDP with Duo props
    By buckeye in forum Volvo Penta Gas Archive
    Last Post: 11-04-2008, 06:38 PM
  5. Props
    By tonyaus in forum Johnson Evinrude Outboard Archive
    Last Post: 08-17-2008, 01:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
