peterdewolf
I have a 3.5hp 2 stroke M3.5A forward gear only. Seems my propshaft is bent. Had it pulled part way up a bank while fishing and a powerboat went past me at speed, sending a wake about a foot high to the bank, lifting my boat up and dumping it and the propellor into the mud. It was buried about 4 inches into the mud.
I've disconnected the gear case from the driveshaft housing and can see that the propshaft gears are nested behind the driveshaft gears ( as you would expect ). The water pump case won't withdraw completely from the proshaft. Possibly this is where it's bent but I can't see a visible bend. can anyone tell me how to remove the propshaft with a view to getting a replacement.
Despite the outward appearance of the engine the gears look immaculate so I'd like to give it a few more years. It's a swine to start but will run all day.
So far
Hope you can help.
Peter
So far
Hope you can help.
Peter
