I just bought an F-32 Trojan which had sank. It's on land now and appears to have been serviced in some fashion. The dipsticks show clean oil and are over-filled. No water on the sticks. I would have filled the engines completely, but this is what I have now.
I want to see if the engines roll over or are seized. Is there a nut on the end of the crank that I can use to rotate the engine the same as on the Chev small blocks?
What else should I look at to determine if the engines have life left in them? I know the carbs will likely need to be rebuilt, ignition and electrical parts changed out, etc... anything else?
