1998 454 Determining MEFI version
djlenny
How do I determine what MEFI version I have..? Have tried Crusader, no response..
1998 454 XLi (MPI)...
I am wanting to purchase a workshop manual and need to know this piece of info..
Re: Determining MEFI version
If the engine is a 1998 then you probably have a MEFI version 3 (1998 software) as MEFI 3 was introduced in 1998.
MEFI 2 was introduced in 1996
Thanks, Crusader have responded stating if the plugs to the ECU are coming out of the top then it is MEFI 3, out the sides (horizontally) = MEFI 2, I will double check with them by sending the part# too..
I prefer to describe the differences as follows:
The -1 and -2 have their connector pins perpendicular to the mounting bolts' axis. the -3 and -4 have their connector pins parallel to the mounting bolts' axis.
Some prefer to use the heat sink fins as the point of reference, same end result.
-3's are nearly impossible to find if you need one; the normal replacement route is to use a -4 and revise the program.
Thanks MakoMark,
I guess a good question in response to that would be, having now determined i have MEFI-2, if there is any benefit of 'upgrading' this to MEFI-4, and have crusader revise the flash..?
I am hoping that once i get my copy of Rinda i can start to troubleshoot my issue more freely..
