1973 Browning Marine
Alright, here we go with another problem! About a year ago I purchased the trim sender/trim limit harness from Mercruiser. I have Faria gauges already installed in the boat dashboard. The gauge is brand new and is wired up as follows:
1) Ignition wire is hooked up to (I) terminal just as the other gauges are powered and everything else works correctly.
2) Ground wire is hooked up To (G) terminal just as the rest of the gauges.
3) Attached a wire to the (S) terminal on gauge and ran it to reach stern area where wire ends of sending unit are located.
The needle on the new Faria gauge shows that drive is all the way up without anything being hooked up to sender yet. First blunder is that I did not label which was the sender unit 2 wire bundle and what 2 wire bundle was the trim limit switch. All four wires are the same color (black) so I am clueless as to what is what. I removed the cover on sender and removed the geared switch that has the rotating contacts attached to it. Everything looks brand new inside so there are no issues with deterioration. I then noticed two brass plates or contacts on the back or inner side of sender harness. Question is this: If I were to find out which was which by testing both wire bundles for continuity by putting 12 volt into one wire and hooking the other through a test light to ground should I not be able to get test light to light up? There are resistance issues doing this I am sure but at this point I am clueless! All I am trying to do is this: I do not want to use the trim limit switch and or trailer wiring setup. All I want to do is have the gauge working off the starboard side trim sender unit. Is there a problem doing so? any help would ge greatly appreciated!
thanks again, Tom
thanks again, Tom
