Even if you were to install these "Extra" springs in the future, the issue may still exist, IMO. Unless these were set-up, and then removed and bagged! Even so, I'd not recommend doing this without checking the curve once again!
Let me explain this in another way..... and please take no offense to the redundancy. You are not alone in not understanding this. I've witnessed so called "marine mechanics" set BASE advance ONLY....., and then walk away, thinking that they are done!
Any slight deviation in spring tension, changes the effect that the spring has against the centrifugal cam weights. These cams/weights control the amount and curve of the progressive ignition advancement. This curve has been pre-determined by the OEM, as to produce power during a certain RPM range, yet keeping "in check", the risk of Detonation.
This can be a very fine balance, even more so for our gasoline marine engines!
(the system in question, is fully mechanical.... no EST using ECU's or ECM's, knock sensors, etc.)
One (1) degree of change to the advancing mechanism, equals two (2) degrees at the crankshaft. Two degrees of change to the advancing......... well, you get my point!
Two or four degrees too much TA at the crank,
and particularly too soon, may...... I say
"MAY" contribute to ignition caused Detonation.
(again, not to be confused with "pre-ignition")
Detonation can be extremely destructive under our sustained Marine Engine loads.
If these springs are rusting, he may have another issue. He may have an engine hatch that is leaking water onto the engine, and into the distributor. These should not be rusting prematurely, IMO.
