1973 Browning Marine
Have a 1988 3.7lx (470) with a 1988 Alpha One standard rotation drive (1:84 ratio). Problem started when I looked on ebay for a used remote control. (Did not have one for the boat so had to start from scratch!) It was advertised as a Mercruiser remote control so I bought it. I get the thing and it reads HILEX on the cover. It had several holes in throw arms for different manufacturers which it listed next to positions.
Found out that it was a (nla) Japanese universal remote control that required 3300 style cable ends. Bought 3300 style cables from teleflex. Drive is on boat and operating perfectly. I can manually engage shift cable and propeller is working in forward and reverse. All is well in that respect. However, when I tried to adjust shift interrupt switch, could not get the throw to work correctly! (gave up after about three hours) Drive is installed correctly, shift cable seems to be working properly, etc. After a few more hours of misery, decided to take drive and control off of boat again and had a marine mechanic friend check it out. He said that the HILEX remote control shift lever had excessive play and or wear. He also stated that this remote was not providing the right throw like the oem remote which he stated was around 3 1/4 inches. I know now that I made a mistake in buying the HILEX control. Also, was told by the mechanic, to make things easier on myself, and just go with a genuine Mercruiser control and compatible cables. He then gave me a used Quicksilver 3000 Classic remote control with the trim/tilt switch on top part of handle, a lanyard man overboard switch, and I guess a neutral safety switch. The guy really went out of his way to try and adjust the shift interrupt with the HILEX control but after about an hour he said something was not right and that is when he gave me the used Mercruiser control. He told me the proper style cables to buy but it was about a month ago and like an idiot I forgot. I hate like heck to bother him again asking the same question twice. Thought you guys might know what type of cables I should use with this particular control. I know what length the cables have to be but am not sure of the type of end to get for the control side. (Oh, by the way, I know that the cables ends are mounted to the control by two screws on the throw arms if this helps). I also know that there is a plastic piece that holds the cable casing in a fixed position to the control. The used Mercruiser 3000 Classic control does not have the plastic pieces that lock the cable casings to the control. I am hoping that the new cables will have this part on them. Any help would be greatly appreciated! thanks, Tom
