DavidW2009
The lower end is off of a 1987 Standard Cobra, 2.3L Ford, and separated from the upper unit.
With the unit on a bench, I push the shift rod down while rotating the prop CW and it shifts into what I think is forward. I continue to rotate the prop and all is smooth.
I then move the rod to neutral and spin the prop. All is smooth and quiet.
I then move the rod all the way up into what I think is reverse. Spinning the prop CCW I hear a muted gear noise. Spinning it CW it's louder.
Maybe I should be turning the driveshaft instead of the prop for this check?
Question: Is it normal for the gears to make some noise in reverse? (Like an automobile reverse makes noise (standard trans).)
