Anyone know if a 1988 Crusader 454 would have flat or roller?
well it was already broke in all those years ago with high levels of zddpI would say there was "no harm" done at the cam/lifter interface from using the lowered zinc oils over the years.
- maybe on the original equipment. The rebuild, over a decade ago, got 30 minutes with quicksilver oil, then a filter and fresh oil. After 25 hours, the synthetic stuff when in. The basis for the "no harm" was the past decade, on the rebuilt engines.well it was already broke in all those years ago with high levels of zddp
The Delo family contains a full line of engine oils, including Delo 400 LE SAE 15W-40 and 10W-30 (CJ-4), Delo 400 LE Synthetic SAE 5W-40 (CJ-4), Delo 400 Multigrade SAE 15W-40 (CI-4 PLUS) and Delo 400 Synthetic 0W-30. Rounding out the complete line of Delo products are Delo Extended Life Coolant, Delo Extended Life Coolant/Antifreeze - Nitrite Free, Delo Greases EP, Delo Heavy Duty EP, Delo Synthetic Grease SF, Delo Synthetic Transmission Fluid SAE 50, Delo Gear Lubricants ESI and Chevron Delo Synthetic Gear.
http://www.ford-trucks.com/forums/557904-cj4-oil-information-vs-ch-and-ci4-oil-specs.html7. Do API CJ-4 oils protect older engines if they are operated on 500 ppm maximum sulfur fuel?
Yes, API CJ-4 oils are designed to have performance benefits over API CI-4 and API CI-4 PLUS oils when using both 15 ppm and 500 ppm sulfur fuel, and qualification testing is conducted using both fuels. As a reminder, 2007 on-highway engines with advanced emissions systems must use ultra-low sulfur diesel fuel containing 15-ppm sulfur or less. In cases where older engines/vehicles are operated with 500 ppm sulfur fuel, API CJ-4 is designed to protect the engine better than API CI-4 and API CI-4 PLUS. As always, users should seek guidance from their engine or vehicle manufacturer regarding specific service recommendations.
Back to Top
Keep in mind the real reason ZDDP (zinc phosphate compounds) is used in engine oil...this are the cheapest highly effective antiwear and antioxidant additives available. They work great and cost little. Other additives work as well or better but cost more. Reducing the ZDDP and adding borate, moly, and other compounds works great.
