sdowney717
I am thinking of blocking off the exhaust passage to intake manifold crossover to keep the intake manifold and thusly carb cooler. As an aide to help keep the fuel in the carb and not vaporizing out and flooding the engine. Also what is left when the gas recondenses inside the motor is likely missing its more volatile elements and I think is a likely contributer to sticky gummed up carnbonated intake valves.
Frankly todays gas boils at a lower temp and I notice the the bowls dry up after sitting on a hot engine. So I think lowering the temp will help a little bit.
Has anyone done this and have info to share on how it affected or not the fuel consumption?
Browsing other internet forums seems to suggest people who have done this have not noticed increased fuel usage. Mostly in the past, this was a trick way to cool the intake charge and get more power from the engine. Todays fuels vaporize well so I dont think it will hurt mileage.
Also I dont like the idea of fuel drying up in the bowls and leaving behind the sludge that clogs up the carb over time. The alcohols and other chemicals that dissolve the varnishes-sludges I suppose, evaporate and then this stuff which is insoluble in gasoline plates out on the inner surfaces of the carb.
The absolute best solution is fuel injection, no free air - gasoline surface to cause trouble.
Alternatively, I have also been thinking of turning off the fuel pressure to the carbs and running the engines till they die. I have an electric priming pump so it is no trouble to reprime. But that takes some thought to actually do it and I dont always remember.
The best thing I could imagine for a carb system would be one that automatically drains the bowls when the motor is shut off. And then it wont recondense in the motor or gum up things.
