bedford 330
Bedford 5.4 Litre (330) Diesel Engine Cylinder Head Bolts 217 Nm (160 lbf ft) Cylinder Head Bolts (Collared Type) 260 Nm (190 lbf ft) Rocker Shaft Bracket Bolts 57 Nm (42 lbf ft) Connecting Rod Nuts 92 Nm (68 lbf ft) Crankshaft Main Bearing Bolts 1/2 in. dia 113 Nm (85 lbf ft) Crankshaft Main Bearing Bolts 15mm dia 170 Nm (125 lbf ft) Crankshaft Pulley Bolt 188 Nm (138 lbf ft) Flywheel Bolts 113 Nm (85 lbf ft) Camshaft and fuel Injection Pump/Compressor Gear Nuts 122 Nm (90 lbf ft) Flywheel Housing Bolts 63 Nm (46 lbf ft) Support Bolt Clutch Fork Ball 142 Nm (104 lbf ft)
hi how are ya i need bedford parts 330 1981 engins, gearbox, rear axle and more. for export
if you can cintact me on 0401938850 will be great.
I.heybo
