MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 16 of 16
  1. #1
    Default 1983 Mercury 70 HP stalls under load
    I have a 1983 Mercury 70 HP that stalls under load. It is getting very good spark at plugs. When I pull number 3 wire it has no effect on how the engine runs. When removal of plug there is a wetness on plug.Engine runs rough. Why in the number 3 piston not fireing internaly? Can someone help me?
    Thanks,
    Emerson2
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    Default Re: 1983 Mercury 70 HP stalls under load
    What is the compression on the # 3 cylinder ??------------Have you checked the reed valves for # 3 crankcase.---------------------Have you checked the lower carburetor for a blockage ( no fuel to # 3 )
  3. #3
    I now am not sure if it is cylinder1 or cylinder 3 but it is the bottom cylinder. Yes I did check the compression and it is top cylinder is 141, middle cylinder is 149, and bottom cylinder is 141. I have not checked the reed valves. not sure where they are.
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    The top carburetor feeds the top ( #1 ) and also #2------------The bottom carburetor feeds #3 and also #2 ------------So there may be something wrong in the bottom carburetor.-------------------The reed valves are internal around the crankshaft.-They can be inspected when carburetor is removed.
  5. #5
    Well I got time to work on my engine. Removed carbs, removed the bowls , checked everything and they are clean and look good. I did find the reed valves. They look good, but what I am I looking for? I did order a new stator because the insulation on the wires have started break and wires have corroded and starting to break. Where do I go from here?
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    What gap will the ignition system fire on #3----7/16" or better???
  7. #7
    I cannot check gap due to type of plugs. You were referring to spark plugs ??
    Emerson
  8. #8
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    Laying plugs on the block is---------- NOT A GOOD TEST FOR SPARK------------------See/test what gap it can jump!!
  9. #9
    Tomorrow I will put some of the parts back so I can check the spark with an ajustable spark tester. I will let you know what I find.
    Thanks,
    Emerson
  10. #10
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,325
    I suspect you have a bad coil. If # 2 runs okay, then there's nothing wrong with the bottom carb.
    Jeff
    PS: I run one of those myself and like them (which is not what most people think of them!)
  11. #11
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,161
    #2 gets fuel from the top carburetor and the bottom carburetor?
  12. #12
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    Correct.
    Jeff
  13. #13
    Join Date
    Jul 2010
    Location
    Skiatook, Ok.
    Posts
    17
    The one and only motor of this type I ever saw had broken reeds and was doing the same thing. You have to split the cases to fix it . also you can't see all of them without spitting the cases.
  14. #14
    Join Date
    Jun 2008
    Location
    Malden, MA,
    Posts
    333
    you can also get a spark tester, plugs in line between your plug wire and your sparkplug, it will light up if you are getting good spark.
  15. #15
    racerone
    I thought that I sent this yesterday. Well I will try thios again. I put this motor back together enough to start. To my surprise it started and ran very well. I did check the spark gap with a spark tester. Opened the gap to about 1/2 in. and I have a very heavy dark blue spark on all three plugs. Not sure what I did but it seems to run great. Maybe the float valve was stuck or dirt in carb. Next i will put it all back together an d try it on the lake. I will make final adjustment to carbs there. Do you think I should do anything else.
    Thanks for your help and support
    Emerson2
  16. #16
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    You may have fixed the problem when you cleaned out the carbs. That's what cured mine; the idle circuit of the top carb was partially plugged. You can hear the motor sag like crazy at the end of the video below.
    Jeff
    http://www.youtube.com/watch?v=1oCSXMSWUEU
Similar Threads
  1. DT75 stalls under load
    By mgn_wp in forum Suzuki Outboard Archive
    Last Post: 10-31-2008, 03:12 AM
  2. Mercury 6HP 4 stroke stalls under load
    By davedylan in forum Mercury Mariner Outboard Archive
    Last Post: 06-26-2008, 09:32 PM
  3. HELP my 35hp mercury is sluggish and stalls under load
    By greazyt in forum Mercury Mariner Outboard Archive
    Last Post: 06-02-2008, 04:51 PM
  4. Stalls under load
    By dawgs in forum Mercruiser Sterndrive Archive
    Last Post: 07-19-2007, 10:59 PM
  5. 1978 90hp Mercury inline 6 stalls with load on it
    By bradccool in forum Mercury Mariner Outboard Archive
    Last Post: 05-11-2007, 12:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
