Attempting to remove the lower unit to change the water pump impeller. Have removed the 6 bolts, trim tab bolt, and set the gear shift to neutral. The lower unit will not drop down with hand pressure/twisting.
Replaced the middle bolts on each side several turns to keep the gearcase from dropping completely and tried tapping on a wooden wedge place on top of the two very small triangular cast "tabs" on the lower unit just below the split line. Wedge kept slipping off the "tabs". Reluctant to go further without some advice from those that know.
