Eric.C
We have had the boat for about six months now, and I want to get a manual for the engines. The survey said the engines were 1996, but the serial numbers were "not observed". I looked around for any markings, and the only numbers I was able to find/read were 14015445 on both; which I found to be the block castings and indicates 1978-1987? After that, the port engine says "GM 16" and some other illegible stamps. The starboard engine says "GM 1P" in the same spot as port's "GM 16".
Those were really the only numbers I was able to find/read. Not looking in the right spot maybe? Suggestions?
Does the block casting mean the engines are 1987 or older, and the old man was full of sh**? Or does that just mean the castings are old but the engine ASSEMBLIES may be newer?
Thanks in advance!
Eric
Thanks in advance!
Eric
