Temperature sender and water psi gauge On Johnson 1977 140hp
Chevytech49
Hi all,
I have a 1977 Johnson V4 140 and I would like to install a Temperature gauge and Water Psi Gauge. Is there any way to rig them up on this engine?
Re: Temperature sender and water psi gauge On Johnson 140
The PSI gauge you connect by a 'T' on the 'pee' hose between engine and cover.
Temp sender kits are available. Normally a small bracket with a contact sender is bolted on the cylinder head (outside).
