Page 15 of 15 FirstFirst ... 5131415
Results 421 to 440 of 440
  1. #421
    Default Re: HELP with Espar heaters
    Brian,
    I have an ESpar heater on my boat. I do not know the model. I am interested in finding out due to the fact it is not working now. The boat was built in 2016. Newer boat and heater. I think it has only ran for one tank full of diesel fuel. Any help would be appreciated.
ID:	17155   Click image for larger version.
  2. #422
    Hello! I recently bought a 43' boat in the PNW. It has an approximately eight year old D10W Hydronic heating system on it the previous owner installed. It seems to be in tip-top shape externally, and the owner paid good money to have it installed. He said it worked fine 9 months ago when he was last on the boat. However, it is no longer working. When the thermostat is turned on, the main unit just clicks ... then ... nothing. No heater, blower, fuel metering pump, etc. I checked to ensure both the fuel pump and the fuel metering pump were in good working order and they are. I've turned it on enough times now I'm pretty sure it is "locked up". It just clicks once every time. Do I need to get the Digimax controller to unlock it and read the faults? Any help would be most appreciated. I've plenty of pictures.
ID:	17446   Click image for larger version.
  3. #423
    Dec 2015
    maplevalley WA
    5,049
    As a hvac tech get a manual and follow the sequence of operation. Are you getting power to the blower motor? Turn the thermostat up and put a large screwdriver on the heater and see if its making any noise when you put your ear on the handle of the screwdriver. Normally there is a pressure switch to prove it has air flow before advancing to the next sequence of operation. If the pressure switch is stuck closed at startup it may also stop the sequence disconnect the switch and then turn the thermostat up if it comes alive connect the switch and see if it fires up?
  4. #424
    Dec 2015
    maplevalley WA
    5,049
    I just looked at the manual check all connections good it will lock out with improper voltage. Under 10 volts or over 15 volts. You can get the 7 day timer it can pull the fault codes.
  5. #425
    Thankskimcrwbr.
    I have checked voltage the control board and am good to go there. I have amulti-max f1000 but it has no LCD display and I've really no idea what theblinking lights mean. The manual is WORTHLESS in describing what the sequencesshould mean. I’ve been told I can use the SD card in my computer to read thefaults, but I can’t find where in the software. The four windows are all forprogramming starts and stops, etc. Nowhere do I see a description of the mostrecent codes. I’ve actually now ordered a digi-max d1000 because it has ascreen and will hopefully be more instructive on unlocking and displayingfaults. The Espar parts of Michigan sales rep says the digi-max will work onthe hydronic systems. I’m sure it’s a simple issue like glow plug or something,but the diagnostic process has been a pain. Below is the startup sequence fromthe manual, I’m not getting past the control unit systems check. Any idea whatthe initial ‘click’ sound is –
    Once switched on, the following sequence occurs:
    • Control unit does a systems check ( flame sensor,
    temperature, safety thermal sensor and various other
    control unit checks).
    • Water pump starts circulating coolant fluid.
    • Combustion air blower starts.
    • Glow pin begins to preheat 20-30 secs.
    • After about 20-30 seconds the Fuel Metering Pumpstarts
    delivering fuel and the combustion air blower ramps upgradually.
    • Once ignition takes place the flame sensor alertsthe
    control unit and the control unit shuts off the glowpin
    (ignition time: 1.5 - 2 minutes).
    Note: If the heater fails to start the first time itwill
    automatically attempt a second start. If
    unsuccessful the heater will shut down completely.
    Note: On initial start up the heater may requireseveral
    start attempts to self prime thefuel system.
  6. #426
    Dec 2015
    maplevalley WA
    5,049
    Until the experts chime in maybe pull the thermal temp cutout and test it for proper operation its not passing the system tests start testing individual components. Just because the previous owner said it worked if you have not seen it work it means little.
  7. #427
    Oct 2010
    Vancouver, British Columbia
    242
    Quote Originally Posted by kimcrwbr1 View Post
    As an ex espar tech of twenty years, be advised hvac guys, these are very different than house furnaces . No pressure switches. It is all electronic resistance based tests by the ecu. It is almost impossible to diagnose this model without espar diagnostic tools.
    Brian Silk
    Avalon Bay Marine
    Vancouver BC
    Canada
  8. #428
    Oct 2010
    242
    Brian silk here. Previously running avalon bay marine in vancouver. Just wanted to let everyone know that ive been out of the business for a year now. Moved to 100 mile house B.C.. ive been absent on the forum but never made it official. I will not be monitering the forum and my old email will be gone very soon. If you need assistance call the tech help line at Espar canada, espar od michigan, or in vancouver call Roton industries. Be carefull of the advise you get here unless it is from someone with direct knowledge of espar. The reason I joined in the first place was because of the bad information given out. All the best to you. Sorry for leaving
    Brian Silk
    Avalon Bay Marine
    Vancouver BC
    Canada
  9. #429
    Dec 2015
    maplevalley WA
    5,049
    Yea just like i thought they are similar to the new tankless hot water heaters. They do not want joe blow working on them and that is understandable. If you feel comfortable just take it apart and give it a complete service alot of times the issue will be obvious. Poor maintenance or installationis 90% the cause of unit failures. Make sure there is no restriction in combustion and exhaust air? Just give it a complete once over before you call a tech rep if necessary.
  10. #430
    Quote Originally Posted by Brian silk View Post
    I just wanted to put it out here that I can give service advise on ESPAR brand heaters. I have been an Espar Marine tech for 16 years and know them inside out. You can message me privately if you wish. I will check the General forum regularily.
    Hi Brian,
    I have an old D7L. I'm not very experienced with these machines. Yesterday I pulled the glow plug, noted that it was dirty and put one in from the spares on board, not new but looking good. The engine started fine after that. (still warm from previous run though).
    Today I tried to start it and it failed 4 times to start. I pulled the glow plug again and noted that it was wet with diesel. I left it open to dry out, (forgetting that diesel doesn't evaporate like gas) and put a new plug in this evening. It started right up but quickly overheated, evident by the temperature of the exhaust pipe at the unit, and shot sparks and flames out the exhaust pipe overboard. I shut it down and of course realized that I had a burner fire due to excess fuel pooled therein. My question to you is, how should I go about removing the excess fuel in the can before I try another start?
    Any help would be greatly appreciated.
    Cheers
    Keith
  11. #431
    Hi Keith
    See above post # 428
    Mark McMaster
    1983 Tollycraft 34SC
    Crusader 270's
  12. #432
    Quote Originally Posted by Mark McM View Post
    Hi Keith
    Hi Mark
    Thanks. Spotted that after I posted. Hoping someone else can help.
    Keith Greig
    Tollycraft 48
    Salubrious
  13. #433
    Great,
    Just thought I would post this here for a reference.
    This is from their web site:
    For technical support, contact us via email at
    [email protected] or by phone at 1-800-387-4800 ext. 2299.
    Or
    Mississauga, Ontario L5T 2B2
    Phone: 905-670-0960
    Mark McMaster
    Crusader 270's
  14. #434
    Thanks Mark. Already contacted them. No reply yet
    Keith Greig
    Tollycraft 48
    Salubrious
  15. #435
    Quote Originally Posted by Keith Greig View Post
    Keith Greig
    Tollycraft 48
    Salubrious
    So I disconnected the fuel, ran it through a start cycle to clear the engine and re-connected the fuel. Normal start after this.
  16. #436
    i am going to install a new Airtronic D4 on my 30' powerboat, but I am unsure of the best place to mount the unit. I have loads of room in my engine bay but have gassers so no go.
    I ideally I would like to install under my salon floor which is a waterproof bulkhead way from the engine compartment. this area houses all the boat systems including electrical, holding and fuel tanks. I have plenty of room to install without being near the fuel tank and separate diesel tank i will install for heater. intake and exhaust routing would be easy and ducting would be so easy.
    just not sure about installing in same compartment as fuel tank, even though they are vented properly....
  17. #437
Name:	Espar fuse blowing.jpg
    We have a Espar D7L on our trawler. I have two questions, in order of importance:
    1. There is a small "Volkswagon" type fuse mounted on the side of my Espar heater. The fuse mount says 8 Amps. This fuse keeps blowing after the unit runs for 15 minutes. Even with a 10 amp fuse. What should I do to correct this problem?
    2. The wiring to the furnace from the house bank is 8 gauge to a bus bar close to the heater, then changes to 3 foot piece of wire that is either 10 or 12 gauge from the bus bar to the heater. Is this 10/12 ga. sufficient, or should we change the 3' section out to the larger 8 gauge? In the past, when voltage got lower the 30 amp fuse would blow.
    Any advice is greatly appreciated. This is my first posting on this forum. I am thankful for it.
    My best,
    Sam Nigro
    (360) 600-2202
  18. #438
    I have an Espar D5LC installed in my sailboat that has been working fine up until yesterday. When I turn it on nothing at all happens, no fan motor starts, nothing. I have an old controller, (not digital) that shows green flashing error code. Looked in manual and it says overheat check blocked vents.
    No vents blocked. I removed unit, cleaned, checked and cleaned glow plug, checked and replaced 25 amp fuse. Still nothing. Any ideas?
  19. #439
    M
    Quote Originally Posted by Don H View Post
    Hi Don.
    did you check both the intake combustion air and the intake ventilation air? Other than that I canít think of anything. My Espar didnít have that warning light. I eventually threw my espar away and bought a Planar. Itís the same dimensions and fits right into the same place using the same intake, exhaust and ventilation infrastructure but for about half the price. Best of luck!
  20. #440
    Hello,
    I have liveaboard customers with a recently serviced D8LC, service performed by a very reputable shop, however they are over the border. After service it was operational without issue for weeks as their main heat source. Customers reported that it suddenly just stopped working. Lights at the controller indicate the unit is operational however there is no response at the unit whatsoever, no fans or fuel pump.
    As far as I can tell voltage is everywhere it should be and the controller is operational. The unit is not particularly accessible, any service within the unit itself will require it to be removed fully, even to remove the access plate. The fuel pump and wire harness is accessible.
    I found a troubleshooting guide for a similar model that suggests, based on what I have found, the problem may be with the ECM. My gut feeling is the problem is with power supply, but it seems all good. At this point I am about to pull the unit down and have a look, I would very much like to avoid it if possible though.
    Any advice is appreciated, thank you,
    Mitch
  1. Heaters
    By fst in forum Mercruiser Sterndrive Forum
    Last Post: 12-03-2009, 07:15 PM
  2. Block heaters
    By vikingboat57 in forum Detroit Diesel
    Last Post: 09-10-2008, 10:57 AM
  3. 8V92 Block Heaters
    By finatic in forum Detroit Diesel
    Last Post: 03-14-2008, 06:14 AM
