The 'old' manufacturer tolerance was in fact 10% up and down from stated.
A 90hp could then be from 81 to 99Hp.
Not uncommon on the factory to 'sort' out the good apples like selling the original built 99 as '100GT'.
Similar the 225Venom engines could make up to 248, but was still sold as 225.
Volvo Penta went the other way with their MD21 that was supposed to be 62Hp, but was never above 57!!!
I used to run all engines 3 cyl and up on my K & O dyno and not test props.
Quite interesting when encountering problems with twin installation where one engine was claimed to be 'bad'.
Technically they might both be within allowed tolerance, but with more than 20Hp allowed difference in the 100+Hp range it could be rather noticeable.
The old cross engines quite easy to 'fix' on the run, a Dremel in the intake ports behind the bypass covers!!
Even worse when two friends bought same type of boat and same engine and one went in circles around the other!!
