Been having problems with WOT, it will run about 15 minutes or so and then starts cutting in and out. I first thought starving for fuel but have eliminated all possible fuel problems. It starts up easy and will idle all day long if you want. I feel now it has to be ignition. I checked the ohm readings on the stator, trigger and switchboxes and they all check good, but since the problem is intermitant I guess they would check good.
What would be the first item to replace or check? I'm thinking the switchboxes since they control three cylinders each. This would make sense when it boggs down as if losing half the cylinders and then they come back on line.
Any help would be appriciated.
If it's not the case go back to the coil on the plug that's dropping.
