Waking up a 140 1987 looper from a 6 year slumber.
Previous owner is a friend and a mechanic . Started right up, but seemed to idle too high. Had to lower idle timing to go lower - which is odd given the motor was setup properly when moth balled.
As a precaution rebuilt carbs (they were spotless) with 4 new mallory kits. Replaced plugs, wires and inspected cylinders - They looked pretty good and linked and sync..
Compression is 125 123 126 114. Not perfect, but solid. I can recheck if necessary.
Idles fine down to 1,000rpm when going lower - at some point - it mis-fires. Seems to give off a puff of smoke when it mis-fires.
I have tried to isolate by pulling individual plugs, checking timing changes when it happens, pulling plugs, nothing obvious.
Plugs have sometimes been wet(seems to change a bit).
Tried checking the re-circ system and it seems fairly decent - without being able to compare to new parts it's possible things aren't as free flowing as new.
No vro, fuel pumps works well. Sprayed motor for intake leak - nothing.
Have factory manual.
Any help would be appreciated.
