Results 1 to 2 of 2
Thread: Transom height
  1. #1
    Default Transom height
    Picked up a older starcraft and knew the transom was shot. Bascically I am stripping the boat and using it for duck hunting small lake fishing.So cosmetics is at the bottom of the list. Now has a 21'' transom and I will have to lower it to 15'' to accomodate my 57 18 hp Johnson, rating is currently 65.Should I make the height 15'' or raise it to where the cavitation plate is just below the waterline to reduce drag, which we did as kids on the hydroplanes we ran.Any suggestions on woods to use, [glue plywood pieces together,then expoxy coating was my first thought] or some other material.
  2. #2
    Join Date
    Oct 2012
    Location
    sacramento, ca.
    Posts
    306
    Default Re: Transom height
    i would set the engine height so that the cavitation plate is level with the bottom of the boat.
Similar Threads
  1. Shaft Length/Transom Height, Confused!
    By andyfender in forum Yamaha Outboard Forum
    Last Post: 11-17-2010, 02:37 PM
  2. Honda bf40 transom height
    By firefighter987 in forum Honda Outboard Forum
    Last Post: 08-12-2010, 11:30 PM
  3. Motor height
    By dawgs in forum Yamaha Outboard Archive
    Last Post: 10-30-2008, 10:49 AM
  4. Transom height
    By cuzzx in forum Mercury Mariner Outboard Archive
    Last Post: 07-15-2008, 08:12 PM
  5. Transom height
    By lancestapp in forum Outboard motors archive 2000-2004
    Last Post: 12-13-2001, 11:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
